Disappearing Menu Bar
dunkster
Post by dunkster »
I am hoping you can duplicate this, it seems to be persistent on two MB Pro's.
Running kJams Pro, Producer downloaded but not yet purchased.
While attempting to try out Producer:
Select any song any song then click Advanced/Producer
Timeline, Inspector, Video windows open
Don’t do anything else (as I did the first time I downloaded producer-- I was just looking)
Then close video window via red x (timeline and Inspector windows are still there but can’t be closed)
The go back to kJams library and play any song - I double-clicked on a random song to play.
The video window comes back showing graphics for the new song clicked but the menu bar for kJams is lost. All other apps have menu bar as normal. Of course, now I know I can use Command-0 to get the menu bar back. But it seems to be a repeatable problem. I also tried this on my other MB Pro and the same thing happens (losing menu bar after closing producer video window).
Running on MB Pro, 4MB Ram, Set for External video through a miniDVI-VGA adapter but not connected to perform above. kJams Pro (but have not activated Producer-- just trying it out)
Hope this is enough info and I am not leaving anything out.
Regards,
Dunkster
Re: Disappearing Menu Bar
send a screen shot of your General Prefs
dunkster
Post by dunkster »
attached below. . .
kJams_General Prefs.tiff
fixed. will be in next release
dunkster
Post by dunkster »
Dave,
This was not a huge issue after I found Command-0 brought the menus back, but the behavior did give me pause when it first happened. Even forcing to kJams to quit and re-running it did not bring the menu bar back.
Thanks for your efforts and I truly love my kJams!
:D
