My rotation list is broken.
Sedge
Post by Sedge »
As of r20, apparently, my rotation list now shows first singer/song for all six entries. I haven't changed the xml since before r18. Happy to send you the xml if it will help.
>>Sedge
Sedge
Re: My rotation list is broken.
Post by Sedge »
Note: it is a custom Rotation screen. The original still works OK.
you must edit your custom rotation screens and add [+sgr] to the LAST item on each "line"
open the built in rotation template to get an idea
if you don't have custom screens, just delete the "producer templates" folder in your kJams prefs folder
home/library/preferences/kjams/producer templates
Sedge
Post by Sedge »
Got it fixed - this must be new as of r19/20 - even your tutorial video doesn't reference this step!!! I knew I wasn't crazy.
Thanks for the help.
>>Sedge
it's brand new. it lets you put any meta data you want in the rotation screens, not just singer and song title.
arrowheaddj
Post by arrowheaddj »
Sedge wrote:As of r20, apparently, my rotation list now shows first singer/song for all six entries. I haven't changed the xml since before r18. Happy to send you the xml if it will help.
>>Sedge
I am using the stock Lava Lounge Screen - have no idea how to make a custom one - not a programmer, sorry - same issue - showing next singer in ALL 6 spots - Please advise - New update did not fix - Came with previous update last week. Also - more frequently than not - Kjams is unable to find the original file and wants me to late it - funny thing - it takes me right to the finder folder immediately. Please help - Using Kjams Pro
arrowheaddj
dave wrote:you must edit your custom rotation screens and add [+sgr] to the LAST item on each "line"
how do I get to he Kjams folders? Sorry - Dumb A$$ new Mac user here - 20+ on Windows and need some friendly advise.
yes no worries, i am fairly new to Macs too but love them more and more as i learn(i'm still a dumbass when it comes to Macs but i'm getting there), just open the mac HD icon, usually in the upper right corner of your screen. Once you open your hard drive, select the Home icon to the left, Then follow the path Dave wrote out. Library/preferences/Kjams/producer templates. Once you find the producer templates folder, drag it to the trash. Thats it. Good luck and let us know if you need anything else.
thanks for that, that is correct.
