Add Singer here/not here to context menu
Sedge
Post by Sedge »
Dave, small feature request - could you add the option to mark a singer not here (and perhaps here, or toggle, or something) to the context click menu on the singer's name under menu? Now that those that are "here" are back at the top again (many thanks, although I found that by hiding/unhiding the list, I could get it to re-sort) it would be much easier to context click on them on the left, rather then have to open the venue so they load on the right with the checkboxes. I may have mentioned this before, but didn't see it here. This would be especially useful to those of us that have a list of 50-200+ singers at a venue.
I run a $$ contest late in the night, and I uncheck those who are not in the contest while it is underway, then sometimes add them back afterwards - keeps the rotation screens clean that way.
I have another request regarding the contests, but will put it in another thread.
>>Sedge
Re: Add Singer here/not here to context menu
done. update coming shortly.
Sedge
Post by Sedge »
Downloaded and appreciated - noticed version number madness again, I assume r19 is junk, hence the quick r20. Umm, small note, auto-update failed due to a "Unix Error" where the file wouldn't unzip in its temp location. Manual d/l worked fine. I assume this is either due to version madness or cached files, as I've technically done two program updates in less than 12 hours. The new messenger stuff is really nice, haven't tried to use it live yet, perhaps now I will. That delayed screen message will be nice too - before I've been copying my text to clipboard so I can jam it in at just the right moment, or to repeat the message.
>>Sedge
