SAYT is very slow...
Steve Lynch
Post by Steve Lynch »
Hi!
I have a question about the search as you type function.. I'm used to my PC software which updates as you type...
I'm on a 3 day old mac mini with 4 GB of ram, and it can take as long as 30 seconds to refresh the screen as I type in Kjams..
Is there a way to index the database, or scan it, or something, that will allow it to run faster, or do you recommend turning that feature off?
It searches lightning fast without it, but I just kinda' got used to it..
I realize it's two different beasts, and yours does so much more than my old one, so i'm definitely not complaining.. just wondered if it was my fault, or a by product of the type of database the software uses..
Re: SAYT is very slow...
