Force music store update
jfbiii
Post by jfbiii »
Is there a way we could have a "force store update" option someplace? I keep running into an issue where I can't get any online store info at all. I'm not sure if the problem is on tricerasoft or not (although with the recent expansion to 30k songs I suspect they've been offline a time with two over the last two weeks). Anyway, it's like the program deletes the reference to the existing tricerasoft xml file and when it can't get the new one, we can't look at the existing one either.
But there isn't anything I can find to tell me that downloading a fresh tricerasoft xml worked or was even attempted. But sometimes it's just blank when I go to look for songs.
jfbiii
Re: Force music store update
Post by jfbiii »
Oh, I know I can force an update by tossing tricerasoft.xml. Forgot to put that in the other post. But it requires a restart of kJams.
okay i'll add that in
