mpeg-File
singwas
mpeg-File
Post by singwas »
Hi!
Is there a way to create an mpeg-file direct from kjams? Or can anybody tell me how to do so?
I want to go to an event where the kJ uses to work with VCDs.
Re: mpeg-File
kJams can export an Audio+G file-pair to QuickTime. If you have a QT encoder that spits out MPEG1 then the answer is yes. if the source of the song you want to export is in any other format then no.
