Can you burn a song to cd with tempo change intact?
MoJoDonahue
Post by MoJoDonahue »
I have kjams lite so far. I exported a file as a quicktime movie with both pitch and tempo changes. Only the pitch was altered in the exported file. Is the tempo change supposed to export too?
Is there a page on this website that explains what the "Burning" plugin does? If I have this feature will it allow me to export files into my itunes or burn cd's with tempo changes?
I would like to make practice cd's to play in my car cd player with pitch and tempo changes intact. (I don't really need to burn cdg's) Do I need to buy the additional plugin?
thanks
MoJo
Re: Can you burn a song to cd with tempo change intact?
Mojo, refer to the documentation section, then plugins then "How to use it"
the short answer is "no".
but i'll add your request to "the list".
thanks, -dave
