kjams Pro
yruthe1
kjams Pro
Post by yruthe1 »
Ientered the kjams site via my Blackberry to see if I can use the product on an IMAC G5. I could not find a place to purchase the Pro/Lite software. All I actually may need is the Lite being that I'm looking to just play Karaoke for a small Cafe??? Maybe someone can give me some info.
Sedge
Re: kjams Pro
Post by Sedge »
The only way to purchase is download the trial version, try it first, then purchase it directly through the software (help menu->purchase). I'd recommend Pro for anything more than just yourself, wife and kids sitting at home.
Re: kjams Pro
My understanding is that you must use the Pro version if you using it for other than personal use.- Brendan
Re: kjams Pro
correct. :)
