I've tried to set up the one click option but for some reason each time I click to purchase I get a message
First you must enter all your "1-Click Settings".
I've got a visa debit card that I want to use for the purchases and the request is for Credit card.
Are we able to use debit cards or do they only accept credit cards, or am I doing something wrong.
Len
On line store
Re: On line store
It's alright, I bought a gift pack for 75 tracks cos it's cheaper.
Len
Len
Re: On line store
i still REALLY want to know what your 1-click settings were before so i can fix kJams to give you a better error message.
can you set your settings back to use a CC, try to purchase a song, get the failure, then quit
then send me your preferences.plist file? pleeeeeease?? if you do you will be helping make kjams great.
if i fix the bug and make a successful purchase with your settings, i promise to refund you your dollar(s)!
Re: On line store
I'll be looking at this tonight.
Re: On line store
Thanks for helping to sort this out.
I think the system you've built into kJams for purchasing tracks is fabulous.
Len
Len
Re: On line store
the problem was, for those of you living overseas, was you must put *some* info in every field, even the "state" field, even if you just put a period (full-stop) (spaces don't count). All set now!
