10 second clips of tittle
Some time ago I asked Dave if he could give us the option of playing the 1st 10 seconds of each track so when I'm having a quite night, potential singers might get the impetus to get up and have a go at one of the tracks they've seen the title to. Dave said he would put it on his list but as we all know Dave's lost is longer than my manhood, so I've come up with a solution for now. I've created an automator workflow that does it for me, simple really, I don't know why I didn't think of it before.
If you follow my lead you'll need to turn off "skip silence" in prefs and don't forget to turn the volume on kjams down I found that if I start kjams playing and then start the workflow it works well.
Len
Re: 10 second clips of tittle
it is still on the list
there are a zillion things on the list
the list is prioritized
thanks for understanding :)
