kJams wont open if its files aren't present.
cutmoney
Post by cutmoney »
This isn't a big deal, and I'm sure I'm the only user with the issue, but here it is...So, I have all of my kJams files (the kJams folder and my karaoke songs) on an external drive. Then, I have an alias to the kJams folder on my hard drive in my "Music" folder. So, when kJams launches, it reads directly from the external drive. This way, I can kJams on one of two different laptops (depending on which on I have with me).
Now, here is the problem, if the hard drive isn't mounted, kJams just doesn't do anything. So, I have to eventually force quit it, plug in the drive, and start it back up. Again, not a big problem, but it's there.
<b>DJ Cut Money C</b>
Thunder & Lightning Sound and Lighting
www.MidwestDJs.com
bug
will be fixed in the next release
