Hi,
Paid for kJams program yesterday (which looks terrific), and now having problems getting started (installation). I'm not sure how to activate kJams PRO. I've also emailed Dave. Ultimate goal is to add a significant number of tunes to kJams from several CAVS sources; JB99; JB 199 & 203GUSB Hard drive.
Thanks for any help you can offer!
Ron Larrivee
ST72305129
Getting started -I need some help.
Re: Getting started -I need some help.
it is very difficult to pay for kJams without having it activate automatically. Most likely, If you paid, you're activated. The only way to foil that process is by not closing the receipt window. But you DID read the very very explicit warning that you must close the reciept window right? Another way to foil it is if your disk permissions are somehow screwed up, which prevents writing of the serial number file. Let me know.I'm not sure how to activate kJams PRO
Meanwhile:
make a folder on your mac
drag all the music from all the xternal sources into that folder
run kjams
drag that new folder onto kjams
DO NOT change the location of the kJams Music folder unless you really know why you would do that. Trust me, you most likely don't.
