Pitch control grey's-out
eshoaf
Post by eshoaf »
I did notice at one point that I couldn't change the pitch (greyed-out) until I restart Kjams.
- I noticed after playing several songs I could not change the pitch on songs that were in the cue (not Playing) within the brower window by clicking on the up/down arrows. After restart of Kjams, it worked ok.
I don't know if this is related to the use of KMA files.
Good Vibrations Mobile DJ
Re: Pitch control grey's-out
are you still seeing this problem? i think it is fixed. make sure you're on the latest version before reporting problems.
