cd rom drive not compatiable?!
i have a new macbook pro with a dvd rewritable drive and kjams is telling me its not compataibe?!
Re: cd rom drive not compatiable?!
where can i get a cheap external cdg drive?
Yup. 90% of drives do not support CD+G. It's like expecting a CD player to play Blu-Ray discs, the hardware just isn't capable, there's nothing you can do in software, you need a new drive.
http://karaoke.kjams.com/wiki/Compatible_Drives
okay i can not find a drive, i seached for the ones on the page and it shows this as the formats, is one of those the same as CD-G?
CD Formats - CD-ROM, CD-ROM XA, CD-DA, Photo CD, CD-R, CD-RW, CD-Extra, CD-Text
Reports are that the Lightscribe drives work. I personally found a Plextor drive on eBay that I use (PX-716UF). Works great.
does the hp dvd1040e work with mac?
successs!!!! now to figure out how to print a song book from kjams....hmmmmmm....
In order to completely confuse you, LightScribe drives do not advertise that they can do CD+G. But they can, rest assured.streetlightindie wrote:okay i can not find a drive, i seached for the ones on the page and it shows this as the formats, is one of those the same as CD-G?
Printingstreetlightindie wrote:successs!!!! now to figure out how to print a song book from kjams....hmmmmmm....
