Music Maestro?
iwebkat
Music Maestro?
Post by iwebkat »
Can anyone get Music Maestro MP3's to play through kJams? The only downloaded mp3s I'm having problems with are these. It seems to give a blip of music at the very beginning, then just the words scroll with no music playing at all.
If anyone has found a work-around, please let me know. Thanks!
Check out the forum Q&A and look for the post title "Stubborn Discs" Hope it helps you out. I have had a problem with a couple of discs also but hey 198 out 200 isn't bad.
turn off "Skip Silence at start of song", then clear your cache. then try again.
iwebkat
Post by iwebkat »
Thanks!!!! You are most wonderful! Now the Music Maestro downloads work!! :D :D :D
yay!
