Enable the Special Characters palette in the Edit Menu
panicBoy
Post by panicBoy »
So we can use umlauts when we're typin' Björk.
jfbiii
Post by jfbiii »
option-u then the vowel getting the umlaut:
ä ë ï ö ü
Same for é : option-e then the vowel getting the accent.
Much faster than looking them up in a palette.
panicBoy
Post by panicBoy »
Thanks for the tip, but that's not only why I wanted the palette, there's a lot more crap in there.
I will totally do that! Meanwhile, you can enable the input menu in apple->system prefs->international->input menu->show input menu in menu bar
then check off the languages you want, be sure to include "character palette" and "keyboard viewer".
After that, a little flag appears on the right side of your menu bar. From there you can always pick "Show Character Palette" which will get you what you want.
btw: this was done a while ago :)
