Playlist not recognizing added tracks
aantix
Post by aantix »
To reproduce :
1) Make a playlist
2) Add two songs to the playlist
3) Double click the first song in the playlist to begin playing
4) Go back to your library
5) Add a new song to your newly created playlist (do not switch to the play, just drag the track from your Library to the playlist)
6) Skip to the next track. Plays second track in playlist.
7) Hit next again, it goes back to the first track.
8) Hit next again and again, it only cycles through the first two added tracks, not recognizing the third track that was added.
This is problematic for I have two screens, and a single playlist for the night. People come up, search the library and just drag their song over to the nightly playlist. But the playlist doesn't recognize their newly added song until you actually switch over to the playlist.
James Lee
Post by James Lee »
I noticed in your other post you commented that you are interested in purchasing kjams. If you are only using the trial version right now then there are limitations such as ... Can't add more than 2 songs to a singer's "Tonight" playlist.
http://www.kjams.com/wiki/Downloads
If you have purchased the full version then obviously this does not help....
aantix
Post by aantix »
James -
The program alerted me that I could add a max of three songs to a generic playlist.
And that's what it supports; a max of three.
The limit isn't the issue.
I start with adding two songs to my playlist by dragging the tracks over to my playlist. I click on my playlist and start the first song.
I then go back to my library. Add a third track to the playlist (which it allows). Now if I sit back and list to the playlist play out, it only plays the first two original songs added. It's not until I switch to my playlist that it actually recognizes the third track that I have added.
James Lee
Post by James Lee »
Yeah ok. I see what you are saying. It does this in the full version as well. You have to click on the playlist, even if only for a split second, to get the new tracks to continue in procession.
sorry i've been out.
i'll fix it.
Update: OMG!! You're right!!!! EEEEeek!!! (Jun 19, 9:24pm)
fixed!
