Use another Laptop
lenskaraoke
Use another Laptop
Post by lenskaraoke »
I know that this must be covered in the forum somewhere but I can't find it
My laptop is faulty and needs to go to apple for repair so I need to use my wife's macbook but I don't know how to transfer the kjams library to the other laptop. Help
Len
drag and drop
just copy the "kJams" folder (inside the music folder)
Also your plugins:
/Library/Application Support/kJams/
you may also want your preferences folder:
/Users/<you>/Library/Preferences/kJams/
put each folder in its respective place on the other computer.
if it goes back to tryout let me know and i'll reset your activations.
Can i also copy these folders from my mocbook to my desktop so my library is on both computers? Is this the best way to also back up my library?
Thank you
that is exactly what is described.
but also you need to back up your *music*.
lenskaraoke
Thanks Dave
I've had my music backed up for a long time and I thought I had kJams library backed up but didn't.
I have now
lenskaraoke
"Eureka"
My optical drive broke so I took my lappy to apple and they replaced it. And guess what......It plays CDGs
A true blessing in disguise. What kind is it?
lenskaraoke
The drive info
HL-DT-ST DVDRW GSA-S10N:
Firmware Revision: AP09
Interconnect: ATAPI
Burn Support: Yes (Apple Shipping Drive)
Cache: 2048 KB
Reads DVD: Yes
CD-Write: -R, -RW
DVD-Write: -R, -R DL, -RW, +R, +R DL, +RW
Write Strategies: CD-TAO, CD-SAO, CD-Raw, DVD-DAO
Media: Insert media and refresh to show available burn speeds
I've also had it successfully burn CDG's that I'm able to play in a CDG player
panicBoy
Post by panicBoy »
Well, now you need to tell us how to break ours...
Dave, i am a little confused now. Is'nt the *music* inside the Kjams folder? If i copy the kjams folder, the music will be backed up at the same time? please help.
If all you've ever done is rip your own CDs and purchase from the music store, then yes, you're right.
But if you started off with a hard drive full of karaoke and THEN added it to kJams, then no, your music probably is NOT in the kJams Music folder, so back that up too.
