x.1b86
natblend
x.1b86
Post by natblend »
x.1b88 and the previous version, the command 8/toggle rotation doesn't work right.. Also the last 2 versions the Kjams icon doesn't show up. That's no big deal.
both times I had to revert to x.1b86 to do a show because sometimes the rotation screen delays showing up.
I'm on Sierra 10.12.6
Thanks, Dave.
Re: x.1b86
oh, you're on macOS 10.12.
sorry but that's an unsupported OS
but even if you were to upgrade to the last supported OS for 32bit mac, which is mojave, 10.14.6, i probably wouldn't be able to help. 32bit is officially end-of-life at this point, i'll make a few more releases, which will direct you to upgrade to 64bit.
if, however, you run b88 on a 64bit mac (macOS 13 or later), and still have the same trouble, i'll fix it.
please let me know
natblend
Re: x.1b86
Post by natblend »
thanks for the reply.
I'll get by until I buy a newer mac
Re: x.1b86
meanwhile, i DO recommend you upgrade your OS to Mojave 10.14.6
that way you're on an officially supported version of kJams at least
when you get there let me know if the bug still exists, and i WILL see what i can do, okay?
:D
