Cable problem
Cable problem
I have a VocoPro Champion-rec that I use for karaoke twice a month.
The last time I used it, I set it up the way I always do, but no sound came out.
I tried playing with various things and finally replaced the 50' cables that I use to connect the amp with the speakers with real short cables that I use when the pieces are stacked together.
That fixed the problem. But what changed? Replacing even one cable with the longer cables silenced the system. What should I look at?
Re: Cable problem
interesting question, but unrelated to kJams. i do not know the answer
