up-tempo playlist
randyj
up-tempo playlist
Post by randyj »
I would like to have a section in my catalog for up-tempo songs. Could kJams help me identify them?
(Got the idea from the BPM field in iPrunes)
if you're asking "hey can i add a new column called 'Up Tempo' that has a checkbox that i can check for songs that i've decided have that 'up tempo feel', so i can then sort my library by 'Up Tempo' and then all those songs will bubble to the top" then the answer is yes.
if you are wondering if kJams has some AI bot that can listen to the music and decide for itself if it is up-tempo, then no.
so which one did you mean?
randyj
Post by randyj »
someday... a bot that can figure out the beats per minute
it would be nice if it could vacuum the carpet too :)
my best answer is: Maybe!
