Minor interface bug
Minor interface bug
Small minor bug:
When you edit the metadata fields, and tab from entry to entry, The song moves to match its new place in the alphabetical order, but the edited field does not. This gives the illusion that you are editing the next field of a different song. After you tab again, things right themselves. Everything is edited correctly, but if you are watching what you type, it gets confusing.
hahah!! good one!! thanks for that :)
