Crash when connected to network but no active internet.
cutmoney
Post by cutmoney »
Here's the problem I found, when I am connected to the network at one of the venues where I KJ and the internet is not active, kJams crashes immediatly on startup. Now, at this location I am using iSpot internet access so although I am connected to the network, I have to log in before I can actually get access to the internet
Once I logged in to iSpot and had an active internet connection, kJams started up with no problems whatsoever. Clearly I have the "Check for updates automaticallly" preference checked.
<b>DJ Cut Money C</b>
Thunder & Lightning Sound and Lighting
www.MidwestDJs.com
thinkin' about this
well 2 things I'm doing here:
1) make sure you have the latest version (my own hand rolled)
2) make sure you're registered (eSellerate does this)
i suspect it's eSellerate that's crashing here.
i think you can shut it off using LittleSnitch.
