sync glitch - need help pinning this down
randyj
Post by randyj »
Hey all you cool cats and gals :)
there's a glitch that has been on-going but I can't seem to pin it down. It's been too infrequent to figure out yet... what's going on that leads to this?
play a song and the lyrics graphics are out of sync with the audio by a second or two. Doesn't sound like much, but as you can imagine, it's real distracting for the singer!
Start the song over, and all is well.
got any ideas? :idea: If it happens to you, try to note EXACTLY what you were doing at the time (use the space bar to play? double-click?) Full screen, other preferences?
The one that's bugging me is I can't remember if the graphics are AHEAD or BEHIND the music. Now, where are those darn CAR KEYS... ?!?
randyj
Post by randyj »
I think I got it. Cats and Cat-ettes, try it out if you like:
2 songs, same title, different manufacturers
already imported to kjams
never played before (?)
play 1st one, no problem
play 2nd one, the graphics lag audio by about a second
play either song again... no problems, including clearing the cache
... as if it's only the FIRST TIME you play a pair of songs with the same title
(not positive on this... I'm pretty sure I've played one or both before in a much earlier version of kJams Lite. Now I'm Pro d49r3)
General Pref's ON: Skip Silence, Show Messages
Apple AU pitch bending OFF
Video size 2, built-in monitor only
I'll email the log file
still investigating. will let you know if i find anything
