dups not showing in kjams
lenskaraoke
Post by lenskaraoke »
This bug may be fixed because I've just downloaded the latest version. the version I downloaded previously was two days ago
In finder, I copied a singers file from one venue and put it into the new venue file and it was there to start with (the singer did a track) but later when I wanted it again I couldnt find it, when I looked in finder the file was showing at the new venue but it was not showing in kjams so I made a dup again and put it in the folder for the new venue again, and when I opened kjams again "Len copy 2" was there. I still couldnt find "Len Copy"
According to finder "Len copy" and "Len copy 2" are there but only "Len copy 2" is showing in kjams
not a good idea
what you really want to do, if it is the same singer, is make an alias and use the alias, otherwise the singer will have separate folders which get out of sync at different venues.
you can tell if a bug has been fixed by looking at the version history. if i don't mention it, it is not fixed.
lenskaraoke
Ah! I made a dup not an alias
