Songs not being taken out of singer's queue after being sung
seanphafer
Post by seanphafer »
Hi Dave,
I've used the 64-Bit version on an M1 MacBook Pro for two shows now, and I haven't had a hang or crash, etc., so awesome work! The issue I have had is that it hasn't been removing songs from the singer's tonight list after they are done. I've had to go and remove them manually from each singer after. Is this a known issue with the 64-bit version or maybe a preference I'm not setting correctly?
Thanks.
SPH
Re: Songs not being taken out of singer's queue after being sung
not a known issue. i'll investigate.
