Song ID question?
dp
Song ID question?
Post by dp »
I have multiple versions of many tracks and often used the Song ID number as a quick way of finding a specific track. I notice that recently (unable to say exactly at which point) I can't seem to find some tracks when I enter the Song ID number. Amongst these tracks are some which I have definitely located using their Song ID number previously.
Question:
Am I correct in thinking that the Song ID number is assigned at the point which I import a track to the library and should thereafter remain constant?
Thanks in advance,
dp
yes definitely. the song ID never changes. the only time you should not be able to find a song by ID is if it has been deleted.
