Lyrics and music slightly out of sync
dennisgsy
Post by dennisgsy »
Having just installed KJAMS Pro on a Windows PC for a friend I noticed a slight delay with the music which lags behind the lyrics on the screen. I have used KJAMS Pro on Macs for many years and have not come across this before. The PC is hard-wired to the PA system so no Bluetooth lag for example. This happens with CDG tracks but I haven’t yet confirmed if it does the same with video tracks, although I’m fairly certain I have seen it happen the same.
Do you have any suggestions how to resolve this?
Re: Lyrics and music slightly out of sync
if it does this with all tracks, you can use Global Slipping:
https://karaoke.kjams.com/wiki/Slipping
dennisgsy
Post by dennisgsy »
Thanks this has resolved the problem. Global slip set to -0.7 seconds.
Is there anywhere to view the current setting?
"GS:" at bottom main window, also in the menu itself
