After update to macOS 12.3 Monterey, KJams 2 kJams2_v2.1b55_x64 crashes on run.
[edit] this is due to python 2 being removed from the OS, which kJams links to
macOS 12.3 - Python Removed, KJams 2 pukes
BarryRichard
Re: macOS 12.3 - Python Removed, KJams 2 pukes
I can't even download kJams 64bit on my new MacBook Pro M1, it says it can't open the file. I am running OS 12.3, I don't know how to get this to run on my laptop at all. I get a long message like the one you posted.
just get the latest 64bit update from the web site.
note they are NOT under "download", you have to follow a link that says "64bit" to get it, they're easy to find if you look
BarryRichard
THANK YOU DAVE!!!
x.1b56x64bit release has got it for Kjams 2 on macOS 12.3.
Wow, what a quick turn-around, and VERY much appreciated! You are THE BEST!
THANKS AGAIN!
Barry
THANKS AGAIN!
Barry
