Can't open kjams
dreben
Can't open kjams
Post by dreben »
I upgrade to Monterey, download 64bit kjams, install it and got this error: Assert Fail: sqlP, in file: '../../../../_source/Music/CBrowserModel_Table.cpp' at line 223. Don't know what to do, need help.
Regards from Bulgaria
dreben
Re: Can't open kjams
Post by dreben »
Hi Dave, Somehow I manage to open it in graphic interface, but I'm not enable to load the files, any files.
In case you attempt to fix the problem, I highly recommend "any desk". Thank you
dreben
Post by dreben »
I went back to Mojave, everything works.
dreben: you can run kJams 64bit, even on Mojave. Can you try it? Be sure to understand how to go back and forth, and what the consequences are.
