Get info shortcut
Get info shortcut
After songs are added, the Cmd-I does not work.
Right now i think it is until i done get info from menu or context menu once.
Re: Get info shortcut
did you select a song before trying command-I? the tracks area needs to have focus, and a song must be selected
directly after import, after highlighting any song, either cmd-i or backspace to delete does not work.
...not a high priority, but i just register.
Here are logs, and i email a video.
kJams 2.log.zip
(7.82 KiB) Downloaded 314 times
nothing in the search box right? don't use search right now it's busted. i fixed backspace / delete in b35.
if it still happens, a video would be great! (your videos are the best! excellent bug reporting!)
