Re: Copying songs to empty playlist
I selected everything in my Library and dragged it to an empty playlist, but only 284 songs copied. In a different playlist only 35 songs copied.
I tried deleting those 35 songs and got these errors:
ASSERT: attempting to remove index 40 from playlist <Singer order> when size is 36
Assert Fail: !is_null_CPLItemP(pliP), in file: '../../../_source/Music/CPlayList.cpp' at line 3284
Then I saw (two rows filled with nothing but dashes), and can’t delete the second line.
Assert Fail: pliP, in file: '../../../_source/Shared/CBrowserWidgets.cpp' at line 153
Then it aborted and I sent a crash report to you at 2:42
Re: Re: Copying songs to empty playlist
thanks, after you rebuild your sqlite library, can you try that again? let me know!
