Searching crash
Searching crash
I got constantly this error when entering the 3d char in search field.
Had to force quit.
Suddenly (when i thought i could reproduce it) it stopped.
I wrote really slow...
Re: Searching crash
And columns changing
Re: Searching crash
does the "Crash when typing in search" still happen?
when you say "and columns changing" what do you mean? can you elaborate?
Re: Searching crash
Yes it happens but 50-50.
I have a hunch it works if i let it handle a character at a time, writing slow.
Kolumns; see the picture in the background strange columns appear. "Purchase code" and such
Re: Searching crash
please start a new topic about "strange columns", we'll talk about that there.
meanwhile re: assert on search typing fast: can you send me your library?
Re: Searching crash
The search and column thing does not happen now.
Maybe some background cache-import...thing was still running earlier.
I try to provoke it.
Re: Searching crash
re: search column thing: how did it happen? you just launch and see strange search columns? or did you right click the header row and see extra columns to choose that aren't usually available?
Re: Searching crash
That (image above) appeared after the search crash, behind the (non working) dialog.
Only then.
Re: Searching crash
Now!
after adding new songs it crashed on search again
I email fresh log
Re: Searching crash
Crashing is triggered when i search and scroll down and up again
Re: Searching crash
Ah! I can search, but if the result goes further than the page and i scroll down past the end. Scrolling back up, it changes columns and crash
Re: Searching crash
Here; clean log file attached.
Started. Searched. Scrolled. Columns changed. Crashed.
kJams 2.log.zip
(10.99 KiB) Downloaded 485 times
Re: Searching crash
cool! can you make a video of that? either use QuickTime for a full screen video capture, or if you use your phone, hold it side ways and ensure i can see the edges of the screen, and please narrate. thanks!
Re: Searching crash
I can't attach a movie i think ....
i email video.
Re: Searching crash
thanks got it!
