Comments
Comments
From within "Get Info", I am not seeing comments. I can put in comments, but the next time I run kJams, they aren't there. I can display comments in the playlists though.
Re: Comments
one of the rules: DO NOT EDIT META DATA in the 64bit version
Re: Comments
Does that mean we can't have new comments anymore? Nor duet comments?
Re: Comments
it means you will lose the data you edit when you go back to 32, and you can ruin your 32bit database by editing meta in the 64bit version. that's why backups.
of course you will be able to edit meta in 64, same as you always could, but if you do, you should restore your 32 from a backup, instead of just trying to run it.
i think it IS a bug that comments are not being preserved in 64, however, that seems like a legit problem! :D
Re: Comments
Since we need to test comments and adding music, I infer that I need to do so twice, once for each version.
So my bug report is that if I select a song in kJams-64 that has an existing comment (I can read it in the playlist), and then right-click that song and Get-Info, I do not see that comment.
Re: Comments
I just opened kJams-64 a few times to check this, didn't play anything, but it aborted each time I closed it. I'm just opening it, closing it, opening it, sending crash report, repeat. I'm trying again, making sure I wait until it doesn't appear to be doing anything in the background. That took a while, but I was able to quit without crashing.
Re: Comments
it sounds like you're reporting a different bug than "comments"? can you start a new thread with that? i'm using the "one thread, one topic" method, else i will definitely lose track of things
Re: Comments
editing comments should be fixed now
