Lame: impossible export audio track from flv file (QTpro741)
ptrubert
Post by ptrubert »
with Perian installed, flv files are readable. Exporting audio track in aiff works properly. Exporting in mp3 with Lame3.97 (installed with installer 1.2) doesn't work. The result is just a small 10ko garbled file.
PowerMac G4 - 1.3 Ghz - 2Gb RAM - MacOS X 10.4.11 - QT Pro 7.4.1 - Perian 1.1
this is a n Apple bug in the way that quicktime interacts with perian and LAME, it is not a bug that i can fix. Apple does not have incentive to fix this bug since they do not want to support third party MP3 encoders.
the alternative is to export to AIF and reimport that and export it to MP3
ptrubert
Re: no mp3 export from flv file QT 7.4.1
Post by ptrubert »
dave wrote:this is a n Apple bug in the way that quicktime interacts with perian and LAME, it is not a bug that i can fix. Apple does not have incentive to fix this bug since they do not want to support third party MP3 encoders.
Thanks for your prompt reply. Meantime, much to my surprise, encoding is working with MPEG Streamclip 1.9.1... (although MPEG Streamclip uses QuickTime components...). But the setting are limited to mode/sample rate/bit rate.
Otherwise, no problem with ffmpegX.
Best regards.
