Red line at end of song placement
Why do I usually have the red line indicating the end of the song, inside of the bar showing how much is played—but occasionally will be on the outside of that bar, to the right?
Re: Red line at end of song placement
it should never be outside the bar. if so, send me that song file.
This one didn't go far after the end:
show the sort column: "Trim End". is there a value in there? if so, set it to "-" and that should fix it.
otherwise, please send me the song file
