Zipped songs under Catalina
I boot to Mojave to run kJams. But today I used Spotlight under Catalina to do a search and got a result which found an error within a Karaoke song. Googling, one answer I found is that the file is zipped with a 32-bit zip program.
Does that make sense? Will we have to convert our songs when before we run kJams under Catalina? Or was that answer messed up?
Screen Shot 2020-03-15 at 6.46.22 AM.jpg (17.42 KiB) Viewed 51645 times
Re: Zipped songs under Catalina
did you test if you could unzip that exact same file under Mojave?
i expect the zip file is corrupt either way. zipping / unzipping a file is unaffected by the bit-depth of the app that did the compression / decompression.
I'll check. Hmm, I went back to Spotlight for that same search and got that message immediately without having a "find". Pulled out a different utility to find where the file is. I could open a different Karaoke zip file with Catalina.
I booted to Mojave and double-clicked on that song and a few others. They all unzipped. Went back to Catalina and got that error with those songs.
send me a zip file that behaves differently between Mojave and Catalina, thanks
Will do.
you're right, catalina can't unzip files that have roman diacritics, when zipped by an OS < Catalina. crap.
i'll have to deal with that!
Is this something that Apple is going to fix?
Or will you need to have an obsolete unzipper forever?
Or will current zipped files need to be converted?
Just curious.
i don't know if apple will fix it. rest assured i'll have some fix for it so you won't have to worry
It may be that Apple has already fixed it. After I upgraded to Catalina 10.15.4 yesterday, I opened a few zipped songs successfully.
you are correct, this problem has been fixed by apple!
