new laptop
new laptop
I have a couple questions to transfer my serial number from old macbook to new macbook. I open kjams, then Help/Reveal preferences/ find the serial xml for jams pro and burner. Can I email them to my new computer, then drag them to the correct spot? Do i then de-activate the old serial# before I activate the new computer?
Also, to transfer my music, i just need to copy the kjams folder to my new computer? to the same place as the old computer? Is this correct? Thanks
Re: new laptop
you've mostly figured it out.
for step by step, follow these instructions.
Re: new laptop
ok, thanks!
Re: new laptop
