"Get CD Tracks" not working for most options
goateeguy
Post by goateeguy »
Having an issue where I'm not able to lookup CD Tracks.
KayJayPro
- When I go to the website and try to subscribe... I create a login and password, hit submit. It goes to a page saying it's going to refer me to PayPal. Then it just goes to the main page at paypal.com.
(i've emailed them about that)
Gracenote
- Gives me a disc not found. Ok that's fair enough... It appears to be working.
freedb
- 500 Command syntax error
- Disc not found
MusicBrainz
- Disc not found
TrackType
-Gives me a huge long HTML error (Can't even see the OK button on the screen, have to hit enter to close)
- Disc not found
I submitted logs via the email process, I also put my forum username in the email to make it easier for you to find. (goateeguy)
(side note I AM able to submit information to Freedb and TrackType)
Cheers,
BJ
Re: "Get CD Tracks" not working for most options
TrackType is officially dead. Turn it off, it will be gone soon.
Are you on the latest update? If not: here's whatcha neeedda do.
after you do that, see if the others work.
i've also emailed KayJayPro. thanks!
goateeguy
Post by goateeguy »
So, I was on the latest version 2.0.2d38. But downloaded and replaced it just in case.
Freedb and MusicBrainz are still giving me a 500 command syntax error
I "submitted logs" and put my username in the body of the email if that helps.
goateeguy
Post by goateeguy »
KayJayPro is also giving me an incorrect password error.
I have emailed the KJP team, they confirm the login and password are working.
I've typed the login and password in manually. I have also copied and pasted them in.
Also http://kayjaypro.com/mainsite/kjams-support/ is blank.
(You link to this in https://karaoke.kjams.com/wiki/KayJayPr ... ns_for_Use
you're right there's a problem i was unaware of. i'll look into it ASAP
Update: i've fixed it. will be in next release. email me if you need it sooner.
