Question about Kjams on PC
I have been using Kjams for years now. It has always performed above expectations. My Macbook pro is on its last legs and I need to upgrade but a new mac is not in the budget right now. I am considering buying a PC for Kjams and other things. Any recommendations on a PC? Is Kjams working as well as on Macs? Is the functionality the same across the platforms once I'm set up ?
Re: Question about Kjams on PC
the functionality is identical, but the performance isn't quite as good. so be sure to get 8-16 Gigs of RAM, and at LEAST a high end quad-core with hyperthreading. speed will be your friend. optional: an SSD for fast database saves and launching. honestly it performs better on mac ( macOS seems to have a much smoother thread management sub-system) so you'll still get better performance on a used mac that is slightly older. (not more than a couple years)
ok, fast forward, I bought a new macbook pro :) Now my question is; Do i need an activation code from you to enter on the new machine?
