Unknown Album
Unknown Album
I see that a bunch of my songs are stored in my kJams Music folder in a folder called "Unknown Album". I decided to look at the songs in kJams and assign a meaningful name to the album, but did not see how to do this. Same thing for "Unknown Artist". In kJams, these songs appear to have real artists and albums. Why are they stored as unknown? Can I change these?
Re: Unknown Album
Unlike iTunes, kJams currently does NOT "reorganize" the file system when you make changes that would SHOULD the file system.
if you feel the need to have your file system perfectly organized, and are willing to start fresh (losing all your playlists and singers), then you can get your metadata perfect, then export to an organized folder structure, then rebuild from scratch using that organization.
Let me know if you care THAT much, normally people don't.
Re: Unknown Album
I don't think I care *that* much, thanks.
Re: Unknown Album
