The Right CD player
The Right CD player
I loaded a bunch of CD-Gs into kJams with a significant number of graphic errors.
I was using a LG slim portable DVD writer that tested out for writing CD-Gs.
David Cotter mentioned "it could be you have a CD drive that doesn’t properly implement error correction", and he was absolutely right.
I got a hold of an Apple USB SuperDrive and am re-ripping all of those CD-G disks. Instead of that multitude errors, so far I have found only one minor error, and reloaded that song successfully.
The Apple drive doesn't have a light showing when it is running, and doesn't have a way to force the disk out (which I needed with my LG drive). And it is significantly more expensive. But it does the job reliably.
Re: The Right CD player
Note: Almost all of the bad rips were from one set of CD-Gs. Quality vendors also matter.
I had a couple of CDs that opened up two places on Finder. I could not close them or eject them, and couldn't even shut down my Mac.
(I had to push the off button.) With the LG drive, I could eject the CD-G with a paper clip. I got "Gal Pop: Volume 1 Disk 2" stuck and went to the Apple Store, where he booted up a laptop holding the left mouse button to eject that disk. So that particular problem doesn't appear to have anything to do with either kJams nor the CD drive.
If your machine has an eject key, you can also just hold that when restarting.
But the easiest way is just to launch Terminal and type:
drutil tray eject
I tried using Terminal (I forgot the command), but what did the trick was re-booting while holding the right mouse button.
or literally pull the USB plug on the cd drive. you'll get a warning about properly ejecting, which you can ignore. when plugging it in, press the eject button. no restart necessary.
