How to Move Songs from Songs Not Renamed
bflowngz
Post by bflowngz »
I have a lot of songs that are in Songs Not Renamed. How do I correct the meta data and then move them into my library?
Also, going forward is there a way to ensure that the meta data is correct before importing files?
Thank you!
Re: How to Move Songs from Songs Not Renamed
how to correct meta data:
https://karaoke.kjams.com/wiki/Meta_Info
if you do not know a song's album name, enter "Unknown Album" as the album name
if you mean before you rip a disc, yes, do this.
if you mean before you "add to library" some existing song files, no, you must import them into kJams, then fix the meta data.
I have the free services turned on, but they don't catch much.
technically, GraceNote is also free, you can just decline giving a donation.
