playlist and signer erase
geoartist
Post by geoartist »
I exported my list so I could print it and all my playlist are gone, my main librairie was not touch. Why and can I retrieve it.
Re: playlist and signer erase
how exactly did you export it?
the only way for a playlist to disappear is if you select it and press delete then confirm in the resulting dialog, OR if you go into the file system and delete it there
