Not able to Upgrade
waynegfx
Not able to Upgrade
Post by waynegfx »
I am not able to download the updates. I click to download and it looks like it is downloading then quits, but nothing happens. I am on Mac High Sierra.
Re: Not able to Upgrade
"If the auto-update fails, you should manually install it. To do so, go to the web site, then download it manually and install it."
waynegfx
Post by waynegfx »
Thank You Dave, I love kJams 2, it is awesome Do I just download the kJams 2 again? I didn't see updates anywhere on the download page
yes just download it. (ie: under "downloads")
