Search bar
Search bar
I really like the search preferences. Just a suggestion; is it possible to make the clear( "X" ) button a little bigger? I sometimes find myself fumbling to hit it the first time. Otherwise cosmetically, It's beautiful.
Cheers
nope it's not
sorry, it's an apple widget, not mine. i'm not about to re-invent the wheel, as that is always a losing battle when Apple changes the theme.
Okay, i understand. How about having the text dissapear when you click on the search bar??
Cheers
ChurchCat
Post by ChurchCat »
Brendan wrote:Okay, i understand. How about having the text dissapear when you click on the search bar??
Cheers
Do you have the tick box clicked in
kJams Pro > Preferences > Advanced > Clear Search Field when switching sources.
CC
Why on earth would you want that to be the default behavior? and if you DO want that, then just click the little "X".
Ummm, Why not?
cuz you type "U2"
and you find all the u2 songs, but then realize there's way too many, so you want to add "love" to the end of "u2" to limit it to the u2 songs with the word love in it, but now you've just erased the text "u2". you didn't want to to do that. and if you did, you would have hit the "X" anyway. there's already a way to get what you want, why force the whole world to want that at all times?
That makes sense. I just dont like that little "X" and was merely making a suggestion.
why force the whole world to want that at all times? ?? Geez , What do you mean?
Cheers[/quote]
What do you mean?
I just mean that, right now there are 2 options, 1: click in the text area to keep typing, does not erase the text and 2: click the box to type something new, that does erase the text.
what it seems you are proposing is to *remove* an option that some people will miss. I'm all about having more options, not having fewer options, that's all. sorry if i sounded curt, i have a brain thing. ;)
I get what your saying and it totally makes sense. Your the expert, i am still learning. Thanks for clarifying for me. Iam definately not for removing any options, i would never propose that. Keep up the great work.
Cheers
Ummm, Why not?
ChurchCat
Post by ChurchCat »
:lol:
Is there an echo in here?
Brendan I expect that you know it but there is another way to get what you want.
If instead of clicking in the search box you double or triple* click, this will highlight the text. When highlighted anything that you type will replace the highlighted text. In effect it gives you an empty text box
CC
*You need to triple click if there is more than one word in the box, else a double click will do it.
You can also drag to highlight the text.
Yeah, thanks Churchcat, i have been using this technique. It works fine.
