Not a request more of a suggestion.
ChurchCat
Post by ChurchCat »
At the moment there are two buttons that are not used. The EQ button the Visuliser button.
I suspect that the visuliser is not going to be used as a visuliser. It might be nice to have the mic volume control hidden behind that button. What do you thnk?
CC
There will one day be a visualizer.
the mic volume control shows up under the speaker volume control when you have turned on the mic. so there's no need to "hide" it at the opposite corner of the window?
ChurchCat
Re: ?
Post by ChurchCat »
dave wrote: the mic volume control shows up under the speaker volume control when you have turned on the mic. so there's no need to "hide" it at the opposite corner of the window?
Might have known that you had the bases covered.
:roll:
I have not used the mic feature yet. I like your thinking though.
:D
CC
