Duplicate track finder
Are there any plans to incorporate some method of finding and removing duplicate tracks in the kJam library? Or does it exist already and I missed it?
already exists:
http://www.kjams.com/wiki/Preset_Playlists
works great
This process couldn't have worked more smoothly. The instructions on the page caution against performing this on libraries in excess of 2000 songs, but it chugged through my >7000 song library almost instantaneously (and trashed over 1600 songs). I'm running this on an Intel Mac, I wonder if that makes the difference?
the difference is the warning is old, it will work on any size library now and go very fast
Re: :)
dave wrote:already exists:
Hmm, I can't find it.
What am I missing?
Did you look in the File menu?
I added that to the directions now.
Oooops! okay thanks for pointing that out, i updated the doc.
