Unable to add songs to library
When trying to add songs to library I receive the following error. Unable to add songs...they are already there. If you can't see them then purge KJams music library. Can you hep?
the error message is wrong, it should read:
http://www.kjams.com/wiki/KJams_Music_Folder
for reference:You can't add songs in the kJams Music Folder to your library, they're already there. If they're not, pick the menu: Advanced -> Special -> Scan “kJams Music” folder for orphaned songs…
did you read the reference?
I'm aware of what the error message says now. I said that that error is wrong, and that it should read something different.
If you've placed files into the "kJams Music" folder then you are on your own because that is NOT a supported action. If scanning for orphaned files does not work then i suspect you've not named them correctly.
please email directly
please email directly and send me your fone number, i'll call you.. i think we're mis-communicating.
