first installation
hatid1
first installation
Post by hatid1 »
Hi,
I try to install Kjams to my mimi mac but I have this error:
Import : Type: mp3 , Component: LAME MP3
Imp/Exp : Type: mpg4, Component: MPEG-4
Initializing Undo System
Allocating MetaData Traits Database
Creating Song Database
Spawning new Que: Push Meta Que
Installing event handlers
Getting App Res Folder
Loading songs into Database
Loading Library
loading library: “kCFHostErrorHostNotFound / evtNotEnb / siInitSDTblErr / kUSBPending / dsBusError / kStatusIsError / kOTSerialSwOverRunErr / cdevResErr / gwFlagErr / EPERM, / event not enabled at PostEvent / slot int dispatch table could not be initialized. / / bus error / / / Couldn't get a needed resource; alert / / Operation not permitted”
Loading Library (Rebuild from scratch)
Creating Clipboard
Creating Task Window
Task window exists.
Creating Graphics Window
Video window exists.
Creating Browser Window
Setting control tracking
Initting callbacks
Initting Sources
Browser source container opened
Initting Tracks
with both versions pro and light
Any suggestion?
Thank you
Giorgio
hmm
PM me your fone number
hatid1
Post by hatid1 »
Dave,
I'm in Italy, I think i too much expensive fix the problem by phone.
If you agrre we continue to use the mail as comunications way.
Let me know as to prosegue the investigation about my problem
Thank you
Giorgio
replied
replied in PM.
(we're trying to set up an appointment)
